Posted by GarryinNC on November 20, 2013 at 17:09:22 from (66.226.43.141):
In Reply to: 200 Coil Question posted by LMack on November 20, 2013 at 15:10:01:
I am not sure where LMack is from, but around northwest North Carolina a lot of folks use 'crank' and 'start' interchangeably. e.g.: "Git in there and crank it up, Earl"
Janicholson: I always appreciate your replies, they are well reasoned, factual and seem to be spot on. Always good info. and a lot of help.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
