Posted by Lmack on November 21, 2013 at 14:59:10 from (24.131.50.165):
In Reply to: Re: 200 Coil Question posted by John T on November 21, 2013 at 09:23:57:
With all terminals removed testing the primary lugs yields an open circuit. The secondary yields a little over 5 ohms. I will replace the coil and get back to you. Thanks. (The condenser, points, distributor cap, rotary button, wires, etc. were all recently replaced with new stuff so with that inside information I suspected the coil which had not been replaced.)
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
