Posted by John T on November 21, 2013 at 09:23:57 from (216.249.76.176):
In Reply to: Re: 200 Coil Question posted by Lmack on November 21, 2013 at 07:15:57:
"BTW John, should there not be a dip in the amp meter when the ignition switch is turned on. "
YES INDEED THERE SHOULD BE and around 4 amps as I posted below IFFFFFFFFFFFFF all the correct conditions are met and in place and working as I described...
"I still suspect the coil because there is no movement in the built in amp meter with a full 6-volts to the input side of the coil."
HOWEVER even if the coil is good theres still no ammeter movement UNLESS the points are good and closed and NOT burned, pitted or carboned or oil or oxide coated!!!!!!!!!!!! Take the coils output (To distributor) terminal and dead ground it then see if the ammeter swings to - discharge when IGN is turned on??? That eliminates and by passes all my described conditions.
Place an ohm meter on the coils LV + and - Primary terminals. If it reads around 1.2 to 2 ohms the coils LV primary is intact, if it reads an OPEN circuit the coils LV Primary is bad/open.
Put a 6/12 test lamp on the coils input and with IGN on it should glow, place it on the output (to dist) and it should glow when points are open (UNLESS LV coil primary is bad/open) but go off when closed (Unless burned or pitted or coated or not fully closed)
Id suspect the points or condensor BEFORE THE COIL
HOWEVER the 2 or 3 tests I described above are so quick n easy to see if the coil is bad/open!!! And it may well be, get a test lamp and ohm meter out to find out if its open?????
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
