Posted by wayne in mn on November 22, 2013 at 10:53:16 from (64.118.12.118):
In Reply to: 200 Coil Update posted by Lmack on November 22, 2013 at 09:39:28:
Take your coil to a marina or small engine shop that has been in business for a long time. ask if they have a Merc-O-Tronic coil tester; This will perform a maximum secondary voltage output test (the spark you want) as well as primary voltage and leakage tests. I use mine frequently to check old & newer coils for performance. TEST, DON'T GUESS!!!
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
