Posted by John T on November 22, 2013 at 11:53:08 from (216.249.76.176):
In Reply to: Re: 200 Coil Update posted by wayne in mn on November 22, 2013 at 10:53:16:
Good point, an actual HV Coil tester is the way to really know and test under actual High Voltage conditions. A low voltage low energy continuity test can tell if a coil is definitely BAD (like an open winding) HOWEVER its common for an actual failue to be due to high voltage breakdown and a continuity or ohm meter test doesn't indicate that test.
IE an ohm meter test cant tell you if a coil is really good even if it passes primary and secondary resistance checks.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
