square tube
Posted by tuckaway on November 22, 2013 at 18:33:03 from (76.20.241.106):
farmall 100, the two bolts that anchor the front lift in the square tube, hope this makes since, why are they so tight? I have two 100s and the anchor bolts for the front right and left lifts on both tractors are the same way.Could this be just rust, two different metals? I have used heat and lubes and still twisted head off one bolt. Any advice appreciated.
