Posted by Mark Robke on November 24, 2013 at 17:23:49 from (67.140.182.126):
In Reply to: square tube posted by tuckaway on November 22, 2013 at 18:33:03:
You should not have to back those bolts out all the way to change implements, just far enough to slide the square shaft out of the tube.. In fact, I believe they are not meant to back out all the way to prevent losing them. When you install the implement these bolts do not need to be very tight; nothing would slide out that far without you seeing it first. Mark
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
