Hello Janicholson, this is the results of your suggestions using the test light.
All points probed made the test light shine. There was no difference in the intensity of the testlight when switching from H to L at the switch. So I guess the ammeter is good, as it was working OK be fore this changeover.
No sparks though, when polarizing the genny. Touched the BAT terminal at the cutout to the field terminal of the genny. Is that correct?
I did grind to bare metal the mating surfaces of the genny and it's mounting bracket. I also probed the the generator body itself and the test light lit up. So it looks like to me that the generator is indeed grounded, RIGHT? Bad generator? The middle brush and the right brush are spaced at 7 cummutator bars apart. Does that sound normal?
The fact that the light intensity of the probe remains the same when switching from bright to dim maybe hints that there might be a problem with the 4 pos. switch. I'm just guessing there. So after doing these tests, those are the only 2 flaws that I see. Whats your thoughts?
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
