cub issue
Posted by Tom Durrer on November 24, 2013 at 05:48:57 from (173.72.185.129):
all of sudden my 1951 cub is acting fuel starved.
Will start with choke out but runs weak and
will almost cut off or cuts off. It also surges
little stronger then weak, to very weak. Playing with the governor rod seems to have no effect on improving the problem.
2 weeks ago put in new points, plugs,new disb cap
and roto cap and it was running great.
I pulled the screen filter going into carb, had a
little trash here and also the carb drain and let
gas drain here. I also drained all gas from main
tank and replaced with new gas. What else could it
be, could it be some type electrical problem.
