Re: cub issue
Posted by gene bender on November 24, 2013 at 06:04:07 from (207.177.56.213):
In Reply to: cub issue posted by Tom Durrer on November 24, 2013 at 05:48:57:
have you did a compression check,leaking gaskets,timing and is the gov linkage set correct
