first thing is... you said it was backfiring, that means timing is out. you said rotor does not line up to #1 wire. you did not say you fixed this. but you are 100 percent confident the timing is spot on.? how do you know this? remove #1 plug and ground it to the tractor with a wire and vise grips. crank engine over ever so slow and watch the timing maks coming into view on compression. as soon as the mag snaps that spark will jump the plug, which you will see. then look at the timing marks and they should be lined up to the pointer. even if the marks are out a bit it will still be ok, just watch out if hand cranking as too much advance it will kick you. as for the carb main jet- 2 1/2 - 3 turns out. mixture 3/4 -1 turn out is a good starting point. then once timing is set can fine tune the carb.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
