Gene, if the stop leak would end up at the bottom of the engine block, would it not just be at the right place to stop an O-ring leak? I very well know that they can leak. My engine showed the same symptom and it turned out that there even was a hole rusted through the sleeve wall were the O-ring sits. Of course, I discovered the hole in the sleeve only after tearing the engine down. The leak was so minimal that I had to pressurize the block before the leak showed up. Crud in the bottom of the block prevented it from leaking worse and it only leaked when the engine was hot. I did, as you suggested, pressurize the block WITHOUT pressurizing the radiator. (I removed the radiator, blocked the lower outlet of the block and fabbed a coupler to the upper outlet to receive my garden hose.)
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
