Re: Tractor Vet..IH 6 cyl gas tractor engines
Posted by John G. Hasler on November 26, 2013 at 08:24:41 from (174.124.86.152):
In Reply to: Re: Tractor Vet..IH 6 cyl gas tractor engines posted by mkirsch on November 26, 2013 at 07:50:01:
> Plus you also just know those oil companies are cheating the octane rating a little. What"s saying the 87 you buy isn"t 86 or even 85?
Auto manufacturers will be blamed if their cars don"t run correctly on the gasoline they specify for them. You can be sure that they are testing.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
