transmission bearings in an H
Posted by gary in neb. on November 27, 2013 at 12:30:57 from (63.224.174.34):
since i wanted to go into the rear and trans of my H to "check things out" since it had water in it, i decided to replace all bearings and seals. trouble is the bearings i can get are not the "xtra" load like what is in there. My understanding is the bearing has one less ball in. considering this tractor will only used to pull a wagon or hay rake now and then, will this really made a big difference? would use these in the trans and rear end.
