Re: transmission bearings in an H
Posted by pete 23 on November 27, 2013 at 16:39:52 from (74.33.85.134):
In Reply to: transmission bearings in an H posted by gary in neb. on November 27, 2013 at 12:30:57:
I count 15 bearing counting pto so a couple hundred dollars don't go very far. I replaced all in one of my H's as it had sat for 15 years and had water in it plus most were worn anyway.
Over the last 50 plus years I have cleaned and inspected a few thousand ball bearings and you can tell if they are serviceable or not if you know what you are looking for. One thing for sure, is they were made out of good material and you don't know for sure what some of them are made of now days. Especially if you get some aftermarket ones. Purity of the material in a bearing is critical along with the process of mfg.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
