400 bolster removal
Posted by Fudd on November 29, 2013 at 15:10:39 from (75.171.160.239):
I need to replace the upper bolster bushing. Will I have to pull that top sector gear off or will it just pry off? I take it I remove the lower bolster and can then drop the upper bolster shaft out the bottom. Will I have to use a slide hammer to remove the upper bushing? The gearbox has a black grease in it. What do I put back in it? Will the pan on the motor hold the weight when I block it up? TIA.
