Posted by Janicholson on November 29, 2013 at 15:21:19 from (74.60.94.18):
In Reply to: 400 bolster removal posted by Fudd on November 29, 2013 at 15:10:39:
The pan will not hold any weight at all. Use the clutch housing behind the engine. Use more than just the jack, block it up with wood, not concrete. The lower bolster is heavy and very awkward. just jack enough to get the tires just touching the ground, and get help. The shaft is held upward by the nut on the sector gear. It is also (now) held up by the taper in the gear. It will need some love taps, and propane torch heat to expand its taper grip on the upper bolster shaft. Do not hammer on the threaded shaft you will destroy the threads, Out the nut on flush with the top, and use a brass or alloy aluminum buffer to avoid damage. The grease in it now is probably corn head grease. It is appropriate to use that, red Mobil 1 synthetic chassis grease, or 90 wt gear oil. The 90 wt leaks out far easier than the others. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
