Posted by Dale Cowle on November 30, 2013 at 13:21:11 from (174.88.205.156):
I recently bought a b275 International tractor that had a new battery. The info I have has that tractor with a positive ground. I was informed the battery was low because of a series of stops and starts in cold weather (glow plugs). When I saw the battery it was connected negative ground. I don't believe the seller ran it much because he was unfamiliar with the hydraulics.If it was connected properly would there be wires changed (regulator?) and polarized thru the field? Should I pos gr it n pol it d term
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and
... [Read Article]
Latest Ad:
[More Ads]
