Re: pos to neg with gen
Posted by El Toro on November 30, 2013 at 14:00:54 from (96.244.7.206):
In Reply to: pos to neg with gen posted by Dale Cowle on November 30, 2013 at 13:21:11:
If that's a 12 volt battery I would check the charging voltage across the battery terminals using a volt meter. Hal
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
