Re: Super C hydraulic pump?
Posted by lti on December 01, 2013 at 06:46:36 from (67.55.255.159):
In Reply to: Re: Super C hydraulic pump? posted by Janicholson on November 30, 2013 at 21:22:51:
Thanks; They must have did that at the valve control they added. Have to check the hoses up there. We have used the cultivator for several years and the levers by the thorrtle lift and work. and the lever for the 2 point lifts and lowers it ok. But if not, will get a line return in there some way. Thanks.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
