Re: Super C hydraulic pump?
Posted by Janicholson on December 01, 2013 at 07:13:36 from (74.60.94.18):
In Reply to: Re: Super C hydraulic pump? posted by lti on December 01, 2013 at 06:46:36:
If it is working as you indicate, it is OK. The use of a control valve with the couplers disconnected is going to cause the system to dead head into nothing. Other than causing the pressure relief valve and pump to strain, it is harmless if done accidently. If kept that way it will overheat the pump and cause system failure. Jim
