Re: start on farmall m
Posted by butch49 on December 02, 2013 at 13:20:38 from (67.142.166.25):
In Reply to: Re: start on farmall m posted by David G on December 02, 2013 at 13:03:30:
I have a 12 volt negative ground alternator, it is hooked 10 gauge from bat on alt, to negative on ammeter,where on the back of ammeter it has a neg sign,10 gauge to starter 12 gauge to neg, of ammeter to ignition switch. took out ballast resistor at moment from ign. to ballast to coil positive side. I have no voltage at plus side of coil.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
