Re: start on farmall m
Posted by rvirgil_KS on December 02, 2013 at 14:48:12 from (192.208.173.110):
In Reply to: Re: start on farmall m posted by butch49 on December 02, 2013 at 13:20:38:
With negative ground, the negative post on coil should go to distributor, positive post to ignition switch via resistor if used.
With switch on, approximate voltages at the coil should be:
Input (switch side) without resistor 12 volts, with resistor 12 volts points open, 6 volts points closed.
Output (distributor side) 12 volts points open, zero volts points closed
Sounds like the coil wires may not have been switched when alternator conversion was done.
