300 Utility Rear PTO question
Posted by bmagee on December 02, 2013 at 18:57:56 from (174.103.17.19):
I am in the process of installing the platform or cover over all the gears from recently installing new axle bearings. I reinstalled the rear pto and want to make sure everything is correct before I install the top.
My question is should I be able to turn the pto shaft? right now I cannot turn the shaft.
Am I ok or have I done something wrong?
Thanks in advance
