B414 hydraulic pump
Posted by Phil Tibbetts on December 04, 2013 at 19:03:27 from (208.93.14.38):
I am working on a B414 with the 144 gas engine. I need to replace the hyd. pump and see some on eBay but they all say for diesel engine. The old one looks just like them and has the same part #. Is there a difference between diesel and gas hyd pumps?
By the way it does not have power steering.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
