Re: B414 hydraulic pump
Posted by Bob on December 04, 2013 at 20:50:06 from (64.255.159.192):
In Reply to: B414 hydraulic pump posted by Phil Tibbetts on December 04, 2013 at 19:03:27:
CIH parts on-line shows the same # for the gas and diesel without power steering pumps. Current # is 704330R95.
Check it out for yourself at the link below:
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
