Re: B voltage regulator revisited
Posted by glennster on December 05, 2013 at 11:39:00 from (75.56.61.3):
In Reply to: Re: B voltage regulator revisited posted by Janicholson on December 05, 2013 at 09:47:13:
jim, i bought a new regulator some years back from my trusty case i-h dealer. the regulator was to replace an old cut out style and eliminate the low-high charge. it had the long resistor on the regulator, and the wiring instructions had you disconnect the resistor inside the lamp switch housing.
