Re: IH560 hydraulic woes
Posted by The tractor vet on December 05, 2013 at 20:25:45 from (75.19.119.134):
In Reply to: IH560 hydraulic woes posted by MaxDamage on December 05, 2013 at 20:12:00:
I would say your problem is STILL water getting into the hyd oil and is plugging your filter . Just because you changed the filter and the oil you did not completely drain the fluid that is still in the loader cylinders and then you have condensation that builds up inside the tractor . If you see the outside of the tractor sweating you can bet your sweet arres that it is doing the same thing inside . The filter is doiing what it is suppose to do and it is filtering out the ice Crystal's and plugging up .
