Yes it's three brush and yes the light switch is re-wired. This regulator has worked moderately from the time I put it on maybe ten or so years ago till two years ago when the amperage finally dwindled down to nothing. It's working now since I cleaned the points and tightened the point tension just a bit. When dad was still active he put more hours on this tractor in the summer than I put on the field tractors. It's been a good little trooper. I put new Pistons and sleeves in it in 1975 and that's the last major work I've done to it. I bought the P&S for 5$ apiece!Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
