Re: B voltage regulator revisited
Posted by gene bender on December 06, 2013 at 05:53:31 from (207.177.56.213):
In Reply to: Re: B voltage regulator revisited posted by fixerupper on December 06, 2013 at 05:02:09:
If you ground the field on the gen what does it charge. It should charge 10-15 amps then if not the gen is bad and probably needing refreshed bushings,bearings and brushes. just remember the reg does not charge the gen does.
