The higher range is correct for the letter series. I would suggest that you contact Joe's Farmall parts. He is Gordon Rice's son, and sell parts for the letter series. He is out of Clarion, Pa. I believe that this site sells gauges as well.
The F series used the lower pressure gauges, except for the F12/F14 which used the higher pressure gauge.
The reason was, that the Regular, F-20, and F-30 engines were mainly splash lubed. The F12/F14 were pressure lubricated, as well as all the letter series.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
