Farmall A Oil Gauge Question
Posted by MRF-Engines on December 09, 2013 at 03:07:45 from (174.130.63.59):
Hello again. I am looking to replace the aftermarket generic gauges on my A with reproduction gauges. I see the oil ones come in two different ranges, 0-15 psi and 0 - 75 psi. Which one is the correct one for a 45 farmall a? We use this tractor as well as show it.
Thank you.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
