Re: Farmall A Oil Gauge Question
Posted by MRF-Envines on December 09, 2013 at 10:55:54 from (174.130.63.59):
In Reply to: Farmall A Oil Gauge Question posted by MRF-Engines on December 09, 2013 at 03:07:45:
Thank you all for the input. The ones I had found were the original style, no numbers, but had different ranges listed in the specs. Just wanted to make sure I got the right one. Thank you!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
