Re: Janicholson Timing marks on an H
Posted by pete 23 on December 14, 2013 at 11:53:27 from (74.33.91.156):
In Reply to: Janicholson Timing marks on an H posted by Bob on December 14, 2013 at 10:02:18:
Like I said before many times on here. The two marks that are close together, the first one coming up when turning the engine in the normal direction of rotation is top dead center for number one cyl and number 4 cyl. The next mark is 5 degrees after top dead center. As the book indicates a 40 degree spark lag in magneto and you want a 35 degree of advance when engine is running, you set the magneto to trip the impulse at that 5 degree after top dead center mark. Now you will have the 35 degrees advance when the engine runs. The spark lag, or impulse lag holds the shaft that has the lobes for opening the points from turning until impulse trips. By that time the piston is on it's way down so it does not kick back. There are no factory marks indicating the total advance while running. There is one other factory mark all by it's self on the pulley of an H that is for lining up the pilot bearing grease fitting in the flywheel. Over the years, marks may have been added to the pulley by someone. I have added a lot of them when I install battery ignition units or when installing fire crater pistons. Different compression ratios require different total advance and the critical timing is when engine is running full throttle, therefore to check the advance with battery ignition units, thus the added markings. With a magneto you have no control over spark advance. Once the impulse kicks off the spark is fully advanced. That is the chief disadvantage of a magneto. On battery ign the advance is gradual with increase of engine speed and the maximum amount of advance is controlled with the slot in the distributor shaft and the rate is controlled with the springs. You can always add marks to any degree you want on the pulley by calculating the circumference of the pulley if you want to actually check to see how far the spark is actually advancing. Who knows what impulse coupling has been installed in that magneto over the years. Different ones have different lag.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
