Ok I understand the principle of what you are saying on the static timing...and I will try it for sure. But with my electronic ignition I have 1 wire attached to the positive side of the coil and 1 attached to the negative side of the coil. The wire going to the disctributor is gone. Should my test light still go on the negative side of the coil?
I know the electronic ignition is not exactly factory...but it seemed to run a little smoother after I installed it. Hard to tell it is there with the cap on.
As far as the gas goes...there is a gas station close by that sells 93 octane with no ethanol...I have started using it.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
