Re: Farmall Super C Engine Sputters (I tried searching)
Posted by Janicholson on December 14, 2013 at 13:11:17 from (74.60.94.18):
In Reply to: Re: Farmall Super C Engine Sputters (I tried searching) posted by dadgummit on December 14, 2013 at 12:55:18:
One side of the coil will be supplied with constant voltage. the other will blink. Use the blinking side to check it. Further it might need to be turning to make the electronic system function. If so using the timing light at cranking speed. Or cranking it by hand (plugs out and grounded)will let you see the marks with no advance. Jim
