CT, Spark should be at TDC! not before or after. Fuel is a problem with most. Pull the fuel line off at the carb. Crank engine over and see if you get a pulse of gas each time you crank it??? If not check the diaphram in pump for cracks. Rice Equipment in PA. has new ones. Also the rod that push's the pump can be worn. I have had to build them up with weld and grind it back to 7 1/16" or so. If you have good fuel flow, carb and float set right, spark at TDC and good compression it should start easy! oldiron29
