Re: Farmall F12 hard to start
Posted by FarmallCT on December 14, 2013 at 16:28:24 from (69.118.77.7):
In Reply to: Re: Farmall F12 hard to start posted by oldiron29 on December 14, 2013 at 16:08:12:
Thanks. It is at TDC, it had been running a little after but now it is on TDC, just enough after I can barely tell so it wont kick back. The fuel pump is working, I get gas each time i crank it, I checked and I went through the carb, cleaned it and replaced the float. It worked better after the carb cleaning but still is hard to start. I may just get a new diaphragm or the fuel pump rebuild kit, i just don't want to get new parts if they aren't the problem. Thanks for the help.
