Posted by ziemerj on December 15, 2013 at 09:30:26 from (70.198.26.30):
I pulled the pistons out this morning. When I removed the number one piston the cylinder sleeve came with the piston. There was a lot of oil between the cylinder sleeve and the block I couldn"t find any cracks in the sleeve not saying there couldn"t be a crack that I can"t see. Is there another cause to this?
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor.
... [Read Article]
Latest Ad:
[More Ads]
