Posted by kjoe89 on December 17, 2013 at 20:44:11 from (71.89.89.22):
In Reply to: 560 cylinder liner posted by ziemerj on December 15, 2013 at 09:30:26:
Do some research. MANY of the 560 blocks were factory oversized in the bore. Poor tooling I think. Rather than scrap the blocks they just bored them out bigger. In turn IH offered a larger od liner for them. I believe they were .008" bigger but verify. Somewhere you should be able to find a spec showing how much force it is supposed to take to install liner. If standard liner is put into over-bored diesel block you WILL brake the liners. Just did one 2 years ago with this exact problem. FP Smith in CA has/had some NOS blocks with liners installed. Still in cosmoline.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor.
... [Read Article]
Latest Ad:
[More Ads]
