806 Hydraulics Quit - Need some help
Posted by BillinCentralMo on December 16, 2013 at 17:08:03 from (107.211.213.228):
Changed the hydraulic filter on the housing by the right rear wheel. No dirt or anything on the filter or the screen. Fluid looks fine. It is making an intermittent squealing barely audible over the engine when you pull the lift lever for the rear arms up. I see no leaks in any hoses nor anything damaged. The guy at the parts counter thinks it is the valve on the seat column and priced it at $285.00. Can you folks help me out. All help and suggestions are appreciated. I am a junior mechanic at best. Thanks in advance for your help
