Re: 806 Hydraulics Quit - Need some help
Posted by The tractor vet on December 16, 2013 at 19:58:14 from (75.19.125.103):
In Reply to: 806 Hydraulics Quit - Need some help posted by BillinCentralMo on December 16, 2013 at 17:08:03:
IF the hyd's were working one min and then not the next and you found nothing in the hyd. filter . And you have no hyd. at all hitch remotes steering brakes , the you have more problems then you want . It may vary well be that the drive center on the pressure plate either stripped the splines or the rivets let go . And if this is infact the case you will have to split the tractor and replace the clutch pressure plate , pilot bearing IDPTO input shaft new seals and a new bearing . Also when your remove the hyd filter you always replace the gskt. never ever use the old gskt or use guppy GOOO .
