Re: Locked up 'M' farmall
Posted by Oldfrmr on December 11, 2000 at 14:35:30 from (152.163.207.82):
In Reply to: Locked up 'M' farmall posted by Wayne on December 11, 2000 at 10:20:32:
Happens all the time on those older "M"s Mine do it too. When you take it out of 1 gear if you hurry it sometimes it's not all the way to the detent and slips back in gear while youre putting it in another. (2 gears at same time) Take shift lever out, by removing cross pin, reinsert in shifter fork, put in neutral, and repeat for other shifter fork. I finally built up my shift lever to compensate for the wear. Works better now.
Post A Followup
: Re: Re: Locked up 'M' farmall
