Posted by pete 23 on December 17, 2013 at 16:25:10 from (74.33.91.156):
In Reply to: Coolant bypass posted by notjustair on December 17, 2013 at 15:17:05:
I would put a plug in it and then you can drill a hole in plug to size you want. Probably start with about a 1/4 inch hole. When you are doing this , take the thermostat housing off. Put a garden hose in the outlet where it connects to radiator. See how much water flows on through. That is most likely the reason your engines does not warm up. You put a lot of water past most of those thermostats because the housing is corroded out inside. You will notice all newer engines that use the tube style thermostat also have a seal in the thermostat housing to allow only the amount of coolant to flow that can go through the bypass hole in thermostat. Some of those holes are also too large and can be soldered shut and then drilled smaller.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
