Re: M bypass - what info is correct?
Posted by TractormanNC on December 18, 2013 at 03:24:10 from (108.72.58.200):
In Reply to: M bypass - what info is correct? posted by Notjustair on December 17, 2013 at 18:57:20:
If you are insistent on closing the crescent shaped passage, get a piece of 1/16 thick flat metal, cut the bolt holes, thermostat hole and whatever size hole you want for the crescent shaped hole. Use a gasket on each side of the plate. NO ruining a good part and it is reversible if you mess up.
