Posted by Nebraska Kirk on December 22, 2013 at 16:32:13 from (207.91.4.159):
In Reply to: Ih 656 ta update posted by Zach Scherf on December 22, 2013 at 16:10:29:
You will have to split it again, some parts will only come out the front end of the TA housing.
That shaft has to be pulled out the front, then you have to pull the TA clutch fork and throwout bearing, unbolt and remove the pressure plate and slide off the driven disc. Then you have to unscrew a large nut off the shaft that holds the clutch backing plate on, then the backing plate will come off and only then can the TA be removed.
This post was edited by Nebraska Kirk at 16:38:31 12/22/13.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
