Re: Okay, Let's Think This Through
Posted by gene bender on December 24, 2013 at 15:16:59 from (207.177.56.213):
In Reply to: Re: Okay, Let's Think This Through posted by Allan In NE on December 24, 2013 at 14:50:57:
Sounds more like the sw was cold as you held the starter position the voltage is routed to the coil so the starting volts isnt dropped to the coil when key is in starting position. Next time put a volt meter on the input side of the coil and watch the reading when cranking using jumpers hooked to the voltmeters leads ive seen those turnkey sw rob the coil volts when key is in the start position. Funny things happen to switches in cold weather maybe a spray of elect cleaner will help
