Notch in 706 cylinder wall
Posted by rnicholas on December 26, 2013 at 14:45:13 from (67.60.123.243):
If anyone can see at about 1 O"clock there"s a notch where the bottom seal is seated for the sleeve (706 rebuild). Is this supposed to be here? It"s not in all cylinders. I mean, if the seal is supposed to keep the water out of the oil (the reason for the rebuild) then why is there a notch where the seal goes? Also, any tips on making sure the sleeve and seal are in correctly when I insert the sleeves? I"m told that if the seal is somehow boogered up then I"ll still have water in the oil pan.
