Re: Notch in 706 cylinder wall
Posted by Dieseltech on December 27, 2013 at 04:47:26 from (98.206.80.148):
In Reply to: Notch in 706 cylinder wall posted by rnicholas on December 26, 2013 at 14:45:13:
Since the area is above the sleeve O ring it will be fine. I am resleeving a D 246 in a Hydro 84 now, there were 2 different size O rings in each sleeve assembly, mine takes the thinner ring. You should measure the O ring block groove to see which ring it needs, should be in your service manual.
