706 D282 Cracked Head.....
Posted by LD in PEI on December 28, 2013 at 13:34:58 from (142.68.104.229):
Blowing snow today, and thought I could smell antifreeze. I got off to have a look and found it weeping out of a crack where the rear bolt right behind the exhaust manifold goes. Looked at my spare head and found it had the same thing. I am not very happy as I just spent a bunch of money on valve seats, planing, gasket and all new exhaust valves around 50 hrs ago, not to mention all the work of the R&R.
It only leaks when running it hard, so my question is if I get some sort of a good sealer, will this stop it? Also will the crack continue to get worse to the point where the antifreeze will get into the oil? I am not that concerned with it if it isn"t going to get worse.
I"m quite sure this was a problem with these heads, and I am hoping someone has some experience to share.
Thanks
